Hi, I have a problem with a block array. Snapping works only at the zero point of coordinates.
(Windows 10)
[SOLVED] No snap at the block array
- test_bloks_array_snapping.dxf
- (101.13 KiB) Downloaded 378 times
- 2021-03-14_14-08-38.png (27.06 KiB) Viewed 4373 times
- 2021-03-14_14-36-00.png (158.53 KiB) Viewed 4373 times
- 2021-03-14_14-32-00 (2).png (156.28 KiB) Viewed 4373 times
Re: No snap at the block array
Thanks. Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2208
Re: [SOLVED] No snap at the block array
The bug was fixed in release 3.26.2.
