Splines that look like circles/slot holes
Q_RIS
Post by Q_RIS » Tue Mar 09, 2021 7:47 am
Hey there, I work a lot with sheet metal parts that are build with different 3d cad programs
and get these parts in unfolded/unrolled state saved in dxf files.
Unfortunatly some of these programs change circles and slot holes to splines when the parts get unrolled.
Those Splines aren't viewed correctly in QCad.
I thought probably the rollback within QCad to OpenDesign Libraries 4.3.2 would help to get it right,
but it didn't.
Is there a possability to workaround or is it necessary to wait til ODA changes that somewhen in the future? Image
(QCAD Professional 3.26.0.0 Win7 x64)
A1mRcur_Panel-part2.dxf
(372.3 KiB) Downloaded 309 times
Re: Splines that look like circles/slot holes
Post by andrew » Tue Mar 09, 2021 8:48 am
Unfortunately, these types of splines with weighted control points are not supported by QCAD at this point.
Q_RIS
Post by Q_RIS » Tue Mar 09, 2021 1:24 pm
Ah yeah, thanks for the clarification Andrew,
so it isn't an ODAImage Issue,
I didn't realize that there is yet another type of splines...
