New Filter in 3.26.1
TSG
Post by TSG » Mon Mar 08, 2021 10:09 pm
The selection filter with the parameter Area of a closed polygon does not work. No polygon is selected that meets the criteria.
On the other hand, a selection filter with the parameter Length applied to the same drawing works.
Re: New Filter in 3.26.1
Post by Husky » Mon Mar 08, 2021 10:49 pm
Same experience on Win10 ... :(
TSG
Post by TSG » Tue Mar 09, 2021 8:21 am
Sorry, I forgot to mention, I'm using macOS 10.15.7
TSG
Post by TSG » Sat Mar 13, 2021 10:15 am
