When I opened a polygonal pattern file, I found that a part of the pattern was missing.
The correct display in other software is:
The display in Qcad is:
My operating system: Win10 x64 Home Edition
QCAD Version: 3.26.0.0 (3.26.0)
I attached my DWG file here: [/url]
Thanks.
[solved] Bug report
- Newbie Member
[solved] Bug report
- QCAD.png (1.27 KiB) Viewed 3910 times
- OTHER.png (1.52 KiB) Viewed 3910 times
Re: Bug report
I have no clue how that was generated but polylines with 1 segment are not the common way in QCAD.
What we can see what is wrong is that your vertices include Z values.
QCAD = 2D
Usually fixed with flatten to 2D but here it doesn't fix the positions.
It seems to go wrong on import.
Over to Andrew ...
QCAD = 2D
Over to Andrew ...
- Newbie Member
Re: Bug report
Hi! Thanks for the reply. A friend sent me a file by using Autocad. I found an error after opening it, so I submitted the question just now.
Re: Bug report
Those entities use an alternative 3D coordinate system (Z axis is pointing to the right) which is not supported by QCAD in this case.
