[solved] Can't display correctly a block
MarcelloP
Post by MarcelloP » Wed Mar 03, 2021 11:04 am
I don't know if it's exactly a problem or perhaps I don't know how to use a block, but on my drawing I have a block (B008) that is not showed well as yoiu can see in tyhe pdf file attaced.
QCAD Version
Versione: 3.25.2.0 (3.25.2)
Internet: QCAD.org
Data Compilazione: Sep 4 2020
Revisione: 4a61501
Versione Qt: 5.13.2
Architettura: x86_64
Compilatore: Clang 10.0.0
MAC Version
macOS Big Sure
Bersion 11.2.2
Thanks for your support
Issue Block.pdf
(78.08 KiB) Downloaded 325 times
Issue Block.dwg
(69.43 KiB) Downloaded 328 times
Re: Can't display correctly a block
Post by andrew » Wed Mar 03, 2021 11:08 am
This problem has been fixed in QCAD 3.26.0:
https://www.qcad.org/bugtracker/index.p ... sk_id=2143
MarcelloP
Post by MarcelloP » Wed Mar 03, 2021 1:45 pm
Just verified and it's correct
