[solved] Pro Vers installation
ChrisM
Post by ChrisM » Tue Mar 02, 2021 10:19 pm
When I purchased QCAD I also paid for the Pro Version, the handbook PDF and the Thumb drive w/ pro-version.
I have the free version running.
QUESTION: How do I activate the Pro Version?
This is what I downloaded:
Re: Pro Vers installation
Post by Husky » Tue Mar 02, 2021 11:11 pm
You can't convert a Trial into a Pro. Just de-install the trial and install instead the Pro.
Post by andrew » Tue Mar 02, 2021 11:48 pm
Running the Full Version of QCAD Professional
Please make sure that after downloading the full version, you also install the full version (not a previously downloaded trial version that still happens to be in your download folder). Please make sure that after installing the full version, you also run the full version (not a previously downloaded and installed trial version). If in doubt, uninstall all versions of QCAD and install the full version from scratch.
Accessing your Downloads
An e-mail was sent to you directly after purchase with a link to your download area where you can download the full version of the software and the e-book if applicable. The link is valid until one year after purchase. The e-mail also states until when the link stays valid.
No key or activation of any kind is required. The download link can also be used to download the software / e-book again and to download updates until one year after your purchase.
If you cannot find this e-mail, please look also in your Spam or Bulk mail folder.
The e-mail subject is "Order / Commande / Bestellung" + your order number. Please keep in mind that you might have used a different e-mail account when placing your order.
You can request your download link again through our website at:
https://qcad.org/recover-lost-download-link
Do not download the free QCAD packages from our public web site as these are trial versions that cannot be turned into full versions.
ChrisM
Post by ChrisM » Thu Mar 04, 2021 9:46 pm
OK, Got it. Pro version running. Impressed so far.
ChrisM
Post by ChrisM » Thu Mar 04, 2021 10:05 pm
Windows 10 64bit
opps... not there yet. QCad Pro loads and works. It stays open indefinitely. There is no box on display that tells me I am running a trial version. However when I try to SAVE or SAVE AS the program shuts down with no message after about 5 seconds.
Post by andrew » Thu Mar 04, 2021 10:16 pm
Please disable the use of the system file dialog under:
Edit > Application Preferences > File > Open/Save > Use system file dialog (uncheck)
QCAD will then use its own file dialogs instead of the one provided by the Windows system which seems to cause troubles on your installation.
ChrisM
Post by ChrisM » Fri Mar 05, 2021 12:34 am
Cool, that seems to work.
Re: [solved] Pro Vers installation
Post by andrew » Fri Mar 05, 2021 10:20 am
Great, thanks for letting us know. I've marked this as solved. Please post any new, unrelated questions you might have to a new topic, thanks.
