SOLVED Leader arrow heads disappear
I am running QCAD Version: 3.24.3.0 in Windows 10 to produce drawings for a house extension. I have generated a number of plans, sections and details to various scales, each as a layout block in paper space. Whilst in paper space, I have added drawing frames, titles and text notes with leader lines. These leader lines are intended to have arrow heads and I have applied a scale factor to them to make the arrows look right in paper space. The problem is that when I save and close the drawing all the leader arrow heads disappear. I got used to putting text notes in paper space when I first used AutoCad several years ago but it looks as though I need to put all text notes and their leaders in model space. Is this the case?
Re: Leader arrow heads disappear
Leader arrows are removed if the arrow size is smaller than half the length of the first leader segment that is hosting the leader. This is a DXF/DWG format restriction.
If you can attach your drawing file with at least one such leader in it, we can help more efficiently, thanks.
Same here:
https://qcad.org/rsforum/viewtopic.php?t=6859
My arrowhead fitted at least twice!
Dismissed as expected behavior.
I'm not sure that I fully understand your reply about the arrow size Andrew but I attach a stripped down version of the drawing in question. It is set to the layer state for "sections" and the "roof detail" block has a number of leaders attached to notes. These leaders should have arrow heads.
- Leader_problem.DWG
- (141.09 KiB) Downloaded 377 times
Same problem ....
The Leader entity (similar as all the dimension types) has a Specific Scale Property.
This is set to 0.1 for a proper arrow size.
I have no problem with that.
I'll vote for this feature.
One can set them but that is reset on save/open.
In the mentioned topic, Husky replied that this is not the correct method/usage.
Instead the global setting for dimensions should be used.
What would be very troublesome in your case.
Regards
Regards
BTW:
A golden rule with hatches is to keep the hatch origin near your hatch.
GRAVEL is a quite demanding hatch.
>> 'Slower' Section A-A, Section B-B & Wall Detail Paper Layout rendering.
It is used 36,000 and 64,000 units away from its origin.
>> Bad coherency.
GRAVEL2 might be somewhat better.
Setting the hatch origin near would be best practice.
BTW:
>> Bad coherency.
Andrews explanation said that the first leader has to be "at least" twice in length of the arrow size. If shorter - the Arrow will not be shown.Eelie wrote: ↑Wed Mar 03, 2021 12:22 pmI'm not sure that I fully understand your reply about the arrow size Andrew but I attach a stripped down version of the drawing in question. It is set to the layer state for "sections" and the "roof detail" block has a number of leaders attached to notes. These leaders should have arrow heads.
I changed the settings a bit - is this how it should be?
Yes, that's what I am trying to achieve but what exactly did you do in settings?
Change the Arrow size to a practical size like 3.5 instead of 50.
Menu / Edit / Drawing Preferences / Dimension Settings
Next: Block List, select "Roof Detail", launch "Edit content of selected block",
use the "Selection Filter" to search and select (Icon "Replace the current selection") all "Leader" in this Paper_Space,
switch to "Property Editor",
below "Specific Properties" change the Scale to 0 and change "Arrow" to Yes.
That should fix the issue ...
Same solution ....
Avoid the use of the specific property Dimension Scale for Leaders.
let us asume that Scale=0 is 'no Scale'. What is mathematically scale 1.0000...
Choose the drawing dimension size to fit your smallest Leader arrows.
Apply larger specific scales to dimensions if those need to be larger as Leaders
That's how I do it since Jan 2020.
In short: Don't scale down, but scale up!
What Husky left out is that 28 dimensions in your drawing need to be updated too.
All dimensions are bound by the global drawing dimension settings.
That's why there is the Scale property (... except for Leaders)
Cheers,
Cheers,
Thank you all for your help. I know what to do now.
Re: SOLVED Leader arrow heads disappear
Posted a feature request.
Picked up as bug and fixed.
https://www.qcad.org/bugtracker/index.p ... sk_id=2196
Thanks Andrew.
Regards
Thanks Andrew.
Regards
