missing file on my computer
plasmaguy
Post by plasmaguy » Wed Feb 17, 2021 4:40 pm
I just downloaded a 32bit version of QCAD on my computer, but it will not run due to the following notice:
api-ms-crt-runtime-l1-1-0.dll missing from computer
Is there a way that I can add the missing file?
petevick
Re: missing file on my computer
Post by petevick » Wed Feb 17, 2021 7:17 pm
what operating system do you use ? which version of Qcad did you download ?
Pete Vickerstaff
Post by andrew » Wed Feb 17, 2021 9:14 pm
I'd recommend installing the Visual C++ Redistributable for Visual Studio 2015 from:
https://www.microsoft.com/en-us/downloa ... x?id=48145
Usually this should not be necessary, but on some systems it appears to be.
plasmaguy
Post by plasmaguy » Thu Feb 18, 2021 3:40 pm
Version 3.25.2 is what I downloaded from the QCad site. I was downloaded in an older PC used with a Plasma system. It has windows 7 because it is an older system, and only runs the plasma table.
