Convert to .DXF
martblek
Convert to .DXF
Post by martblek » Tue Feb 09, 2021 6:41 am
I need to rename a few items in several drawings (about 110). I solved the problem with a simple script in python. The problem is that it only works on DXF files. But I have drawings in .DWG. The procedure is such that I search for every "MTEXT" in the file and when it comes across the searched one, it renames it and then saves the whole drawing under a different name.
Unfortunately when converting with "dwg2dwg -f -d -r 24 -o neco.dxf neco.dwg" it reports a font error for each drawing. It saves it correctly but when loading in the old Solidworks 2D editor it then replaces the fonts and the drawing is unreadable :( is it possible to set the conversion so that it does not pay attention to fonts?
Is it not possible to write a script directly in QCad that would not need conversion and change "MTEXT" directly in DWG?
Thanks.
PS: In "MTEXT" searching for "GAxxxx" and renaming to "GAyyyy"
My idea is some skript "DWGEdit --renameto GA1533 sourcedwg renameddwg"
Is that possible in QCad script ?
test.dwg
(91.07 KiB) Downloaded 307 times
result.dxf
(806.53 KiB) Downloaded 299 times
martblek
Re: Convert to .DXF
Post by martblek » Tue Feb 09, 2021 6:49 am
There is error.
This is from dwginfo
06:45:15: Debug: RGLES3DPlugin::initScriptExtensions
06:45:15: Debug: Input file: C:/Users/bilekm/Desktop/OTHERS/Pracovni/vykresy\test.dwg
06:45:15: Debug: calling odInitialize
Warning: DirectWrite: CreateFontFaceFromHDC() failed (OznaŔuje chybu ve vstupnÝm souboru, nap°Ýklad v souboru s pÝsmem.) for QFontDef(Family="Fixedsys", pointsize=100, pixelsize=20, styleHint=5, weight=50, stretch=100, hintingPreference=0) LOGFONT("Fixedsys", lfWidth=0, lfHeight=-20) dpi=144
Critical: QWindowsFontDatabase::fontDefToLOGFONT: Family name 'gdt;r}\H3.50;???????????\P5.\H2.27;{\fgdt;r}\H3.50' is too long.
Critical: QWindowsFontDatabase::fontDefToLOGFONT: Family name 'gdt;r}\H4.00;???????????(0??)\P \H2.60;{\fgdt;r}\H4.00' is too long.
2627
PS: Dwg2csv script is not in installation :(
WIN10, QCADCAM Pro 3.25.2.7
Re: Convert to .DXF
Post by andrew » Tue Feb 09, 2021 10:42 am
I can confirm that QCAD has troubles decoding some of the texts in this file. I think not all texts are using the same codec / code page. I honestly don't know how this can work, but it's not something that is supported in QCAD, sorry.
Ps: dwg2csv was added to QCAD Professional and QCAD/CAM in version 3.25.2.9.
