Menu Font Size
fastbike
Menu Font Size
Post by fastbike » Fri Jan 22, 2021 6:04 pm
Hi
I'm using version 3.25.2.0 running on Ubuntu 18.10.
My problem is that the menu fonts are extremely small. I can use QCAD on my laptop screen (13") but if I move the QCAD session to the 30" attached monitor the menu fonts are unreadable.
How do I change the font size ? Screen shots attached below
David
Screen shot from 13" laptop screen
Screenshot from 2021-01-23 06-00-47.png (59.98 KiB) Viewed 16736 times
Screen shot from 30" monitor
Screenshot from 2021-01-23 06-01-45.png (60.43 KiB) Viewed 16736 times
fastbike
Re: Menu Font Size
Post by fastbike » Fri Jan 22, 2021 6:29 pm
I've just been poking around the install directory and found the file opt/qcad-3.25.2-pro-linux-x86_64/qcad
This file contains the lines
# breaks on some systems:
# disable if QCAD renders too large
QT_AUTO_SCREEN_SCALE_FACTOR=1 LD_LIBRARY_PATH="$DIR" "$binary" "$@"
If I comment it out, QCAD won't start. If I increase it to 2 there is no difference. If I set it to 0 then the menu font is fine but the toolbars are unusably small.
Am I looking in the right place to fix the problem ?
fastbike
Re: Menu Font Size
Post by fastbike » Fri Jan 22, 2021 6:41 pm
and changing it to
QT_SCALE_FACTOR=1.5 QT_AUTO_SCREEN_SCALE_FACTOR=1 LD_LIBRARY_PATH="$DIR" "$binary" "$@"
Makes the UI scale OK on the large external screen but the menu small (and largely non functional i.e. menu can be clicked but does not show the child items on some menus, others have huge amounts of blank space before sub items etc)
Am I on the right track ?
fastbike
Re: Menu Font Size
Post by fastbike » Fri Jan 22, 2021 7:01 pm
Changing it to
QT_FONT_DPI=96 QT_SCALE_FACTOR=2 LD_LIBRARY_PATH="$DIR" "$binary" "$@"
Fixes the UI problems (all the widgets appear at the right size), and the menu fonts can be read but only a few of the menu items contain sub items when clicked.
So still looking for a solution here.
petevick
Re: Menu Font Size
Post by petevick » Fri Jan 22, 2021 7:08 pm
You can change the menu font size at Edit>Application Preferences>Widgets>Menu Bar. You'll get a message saying you have to restart, but I've found that's not necessary.
Pete Vickerstaff
Re: Menu Font Size
Post by Husky » Fri Jan 22, 2021 7:21 pm
What's about scaling the User Interface?
Used scale factor = 1
Used scale factor = 2
bob93
Re: Menu Font Size
Post by bob93 » Wed Jun 21, 2023 3:53 am
Can you not do this for the tool matrix?
Also, can you change the font type for the menu bar / tool matrix?
petevick
Re: Menu Font Size
Post by petevick » Wed Jun 21, 2023 6:30 am
No, not using Qcad settings, but you can by using my Qcad Theme Designer - https://www.qcad.org/rsforum/viewtopic. ... 493#p40493 - enable Font Overrides, the menu bar and items are on Fonts 1 tab and Tool Matrix is on Fonts 2 tab.
Pete Vickerstaff
bob93
Re: Menu Font Size
Post by bob93 » Thu Oct 05, 2023 1:16 am
Hi, I tried theme designer today, enabled font override and checked BOLD everywhere in all tabs, but the tool matrix item names still remain the same, e.g. they are not bold. Are these item's font properties unchangable?
https://postimg.cc/wy8mmQTS
petevick
Re: Menu Font Size
Post by petevick » Thu Oct 05, 2023 6:52 am
Are you sure that you have the Bold check box ticked for Tool Matrix on the Fonts 2 tab.....
....as it definitely works.....
Pete Vickerstaff
bob93
Re: Menu Font Size
Post by bob93 » Thu Oct 05, 2023 11:36 pm
Absolutely. Notice that my tool matrix is set to list view. The category names such as Point did change to bold, but the item names such as Single Point PO didn't change to bold
petevick
Re: Menu Font Size
Post by petevick » Fri Oct 06, 2023 6:37 am
I'm sorry, I misread your post, I was unable to find a way to change the items in the Tool Matrix.
Pete Vickerstaff
petevick
Re: Menu Font Size
Post by petevick » Mon Nov 13, 2023 8:37 pm
@bob93 - I've finally found out how to change the Tool matrix list view item text (they are actually tool buttons). You can add the following to blank line 436 in your stylesheet.css file (make sure no extra lines are added)....
QTreeView#ToolMatrix QToolButton {font-size: 10pt; font-weight: Bold; font-style: Normal;
You can change the font height and style to suit yourself, font-weight can be Normal or Bold, font-style can be Normal or Italic. :)
Pete Vickerstaff
petevick
Re: Menu Font Size
Post by petevick » Wed Dec 13, 2023 10:12 am
This is now included in the latest version of Qcad Theme Designer - https://www.qcad.org/rsforum/viewtopic. ... =15#p42958
Pete Vickerstaff
bob93
Re: Menu Font Size
Post by bob93 » Mon Feb 26, 2024 10:03 am
I only now see this, but I don't quite understand. Line 436 of my stylesheet.css file is not empty. This is what the file says from line 434:
QScrollBar::sub-line:horizontal
    width: 18px;
    subcontrol-position: left;
    subcontrol-origin: margin;
Can you give me another reference to find the part where I must place the code you gave?
