Invisible objects turned visible
Post by CVH » Wed Dec 09, 2020 6:37 am
Andrew,
Loading a file like here:
https://www.ribbonsoft.com/bugtracker/i ... sk_id=2021
And saving it back as a copy turns the 'invisible' objects visible.
Sure there are other issues with the file ... Like the size, the entity count, ... :wink:
I used it to test my 'Quarantine hatches' script in rather unreal situations :
https://qcad.org/rsforum/viewtopic.php?f=30&t=7842
The invisible nature is supported by QCAD in loading.
Why isn't it kept 'as is' while saving?
I read in REntity.cpp:
    if (isInvisible()) {
        // entity is invisible (part of a dynamic block and turned off):
        return false;
There is clearly a difference between:
REntity.IsVisible
true if this entity is visible (i.e. is on current or given block, is not on a frozen or hidden layer or in a frozen block).
and REntity.isInvisible that can be an individual setting for an entity in a block.
Or has that to to with the fact I standard save in dwg R27, while the original is dwg R18?
