[SOLVED] Orphan Hatches missing in viewport
Post by CVH » Tue Nov 24, 2020 11:44 am
Just detected that Orphan Hatches are missing in the viewport.
2nd file here:
https://qcad.org/bugtracker/index.php?d ... sk_id=2063
Topic here:
https://qcad.org/rsforum/viewtopic.php? ... 063#p28383
Can't do any benchmarks on them, pitty.
Re: Orphan Hatches missing in viewport
Post by CVH » Thu Dec 10, 2020 10:23 am
Suggestion >> Bug Report at:
https://qcad.org/bugtracker/index.php?d ... sk_id=2144
Fixed...
Thanks, Andrew
Re: [SOLVED] Orphan Hatches missing in viewport
Post by CVH » Tue Dec 22, 2020 9:11 am
Solved in Version 3.25.2.7
Thanks Andrew.
