Undo Convert to mm fails dims
Post by CVH » Mon Nov 23, 2020 6:40 am
Continued from this topic:
viewtopic.php?f=33&t=7818
Hit Undo >> Labels of Dims hover in space.
Same as with any dim texts CU from mm to inch followed by an Undo.
Explained as intended behavior:
Husky wrote:
Sun Nov 22, 2020 8:47 pm
After that undo you have to select the dims and Reset the Label position below Menu / Dimension.
IMHO Undo = UNDO the last action and not REDO your drawing yourself
My bad.
I give in.
End of story.
