[solved] wrong keyboard layout
salud
Post by salud » Mon Nov 02, 2020 4:28 pm
Linux Suse 15.1 / QCAD Pro 3.24.3.0
Keyboard layout in Suse German, in QCAD USA Layout. Language in QCAD fixed to German.
How can I change QCAD keyboard layout to German also.
Erwin
Re: wrong keyboard layout
Post by andrew » Tue Nov 03, 2020 10:24 am
I couldn't reproduce that problem here so far.
What exact package do you have installed?
qcad-3.24.3-pro-linux-x86_64
qcad-3.24.3-pro-linux-qt4-x86_64
qcad-3.24.3-pro-linux-qt5.13-x86_64
qcad-3.24.3-pro-linux-x86_32
qcad-3.24.3-pro-linux-qt4-x86_32
qcad-3.24.3-pro-linux-qt5.13-x86_32
salud
Post by salud » Tue Nov 03, 2020 2:44 pm
Installed is 3.24.3.0 5.8.0 x86_64 gcc 4.8.1
Revision a3bef72
salud
Post by salud » Tue Nov 03, 2020 3:19 pm
change in Suse Setting / Region and Language to an other german keyboard (Deutsch Österreich, keine Akzenttasten) solves the problem.
salud
Re: [solved] wrong keyboard layout
Post by salud » Sun Nov 15, 2020 8:42 am
Sorry to say, that after restart of the Computer the problem still the same. If I change the keyboard layout from Austria to Germany or back QCAD recongnizes the correct input. After restart of the computer QCAD again works only with US keyboard layout again.
