[solved] grid not showing when drawing
- Newbie Member
Using a Mac; QCAD PRO
Started a drawing but when came back to it i no longer have yellow lines to position starting point on any of the
drawing tools
drawing tools
Re: grid not showing when drawing
Please check if "Cursor / Show crosshairs" is ticked
- Newbie Member
Have checked those settings and are on.
- This is to draw a line but will not produce the line
- Screen Shot 2020-10-15 at 2.59.16 pm.png (399.84 KiB) Viewed 5824 times
Thanks. What's about the Cursor color. Did you change anything?
Looks more like the default grid settings are off.
Please check under:
Edit > Application Preferences > Defaults for New Drawings > Grid
Recommended values are auto for all and Display Grid checked.
Alternatively, reset your QCAD configuration:
Please check under:
- Newbie Member
Thanks for your help; but no I haven't changed colours.
Have taken another screen shot. The curser and grid will attach to XY position but not move from there. at the bottom of screen under command line box it says no coordinates selected.
I have normally used Auto CAD, but since I retired from my place of work have no access to it. QCAD seems to be the best alternative for what I need to do.. I have just started playing with it.
- Screen Shot 2020-10-15 at 2.59.16 pm.png (399.84 KiB) Viewed 5786 times
- Newbie Member
Sorry added wrong screen shot
Ross
Ross
- Screen Shot 2020-10-15 at 2.59.16 pm.png (399.84 KiB) Viewed 5785 times
Did you check your grid settings (see my post above)?
What happens if you turn the grid off? See my screenshot and click the "Free" snap tu turn it off:ross firth wrote: ↑Thu Oct 15, 2020 10:33 pmHave taken another screen shot. The curser and grid will attach to XY position but not move from there.
- Newbie Member
Solved
Solved, thanks
