[solved] Dark theme causing Layer List text to be unreadable
- petevick
- Premier Member
When using the dark theme the alternate test lines in the Layer List is almost unreadable, see attachment
- dark theme.png (22.22 KiB) Viewed 2679 times
Pete Vickerstaff
Re: Dark theme causing Layer List text to be unreadable
You might want to choose a different (darker) alternating color under:
Edit > Application Preferences > Widget > Layer List
- petevick
- Premier Member
well that was quick and easy, I'd trawled through preferences as well, obviously not well enough!
Thanks Andrew for the quick response
Pete Vickerstaff
