Dark/ light theme not switching completely
Hi, I have a question about the switching of the theme. On my Mac (MacBook Pro (16-inch, 2019 with MacOs Catalina) is the switching between the dark and the light theme not correct (I think). I have set the theme in QCAD on "Default". QCAD switches the theme according my MacOs- right? But some icons stay sometimes black (when switched to light theme) and light (when switched into dark mode in the evening). You can see it on the attached screen shot. I work now with Version: 3.25.1.0 (3.25.1). Can you tell me what to do? Thanks.
- Switch night ot day 1.png (802.08 KiB) Viewed 2282 times
Re: Dark/ light theme not switching completely
Confirmed. You'd have to restart QCAD to switch between Dark / Light mode under macOS.
