I have problem if i want export drawings into PDF or only print.
I'm using "-recompute-dim" in start QCad because i have a lot of garbled drawings. This solves my problems.
But if i change paper size to another paper format because drawings is not A4 these errors appears again.
Drawings changes to default / like opened without -recompute-dim /.
Any workaround ?
Win10 and QCadCam 2.25.2
Paper size problem with "-recompute-dim"
Re: Paper size problem with "-recompute-dim"
We'll look into this and possible workarounds. The problem should also be fixed for the next release.
ok, thanks
An immediate workaround is (if you are comfortable using scripts):
Misc > Development > Script Shell
Enter this in the script shell at the bottom and press enter after each line:
Then switch to print preview.
Replace the height / width with the desired paper size.
doc=getDocument();
doc.setVariable("PageSettings/PaperWidth", 210, true);
doc.setVariable("PageSettings/PaperHeight", 297, true);
thanks, this works.
Is possible to make option that automatically set paper size to match drawing after loading ?
It's possible through scripting, yes.
You might also want to look at the command line tools which have various options to automatically generate PDF files from DXF/DWG drawings:
https://qcad.org/products/qcad-command-line-tools
In particular dwg2pdf and bbox might be interesting.
