I have troubles with opening some dwg files. It tells me "loaded sucessfully", it can also recognize the autocad format:
Drawing loaded successfully: X:/F-20-03-00.dwg
Format: R15 (2000) DWG Drawing (OpenDesign) (*.dwg)
But nothing is displayed on the screen. Is there advice how to solve it? Converting to other older / newer / dwg / dxf format does not help.
Thanks, Ludek.
DWG file is not displayed
- F-20-03-00.dwg
- (262.79 KiB) Downloaded 304 times
Re: DWG file is not displayed
QCAD version: 3.24.3.0 (3.24.3)
Operating system: WIN 7, 64
The entire drawing was created in a layout block (unusual, but no problem).
- View > Block List
- Double-click on "Layout 1"
- View > Block List
Thanks a lot for the hint. It works!
Ludek.
Ludek.
