Hi All
This only happens with QCAD/CAM , QCAD Pro Works Fine any ideas?
Cheers
John Hyslop
Access is Denied [ SOLVED ]
- Premier Member
- Access is denied.jpg (93.94 KiB) Viewed 3664 times
- Premier Member
Re: Access is Denied
Hmmm
It's now happening with both? I might try restarting my pc,
and maybe reinstall..
Cheers
John Hyslop
Cheers
John Hyslop
- Premier Member
Re: Access is Denied [ Solved ]
IT WAS AVAST - BLOCKING QCAD...
Re: Access is Denied [ SOLVED ]
Hi, John.
Somewhere mentioned inside the forum ...
Updates and Snapshots come at that rate Andrew can't get them validated in time by every Antivirus App.
You have to add an exclusion yourself.
- Premier Member
Hi CVH
I already did, that's why I marked this post [ SOLVED ]
I posted it was AVAST antivirus that caused the issue so others could see...
Cheers
John
Cheers
John
'Solved how' is also important.John Hyslop wrote: ↑Sat Aug 08, 2020 12:52 pmI already did, that's why I marked this post [ SOLVED ]
- Premier Member
I said the virus software was causing the
problem..anyone with half a brain would know
to add the exception...
Enough said don't turn this into more than it
is...
Regards
John
is...
Regards
John
