Pdf rendering not working properly
gbhartia
Post by gbhartia » Sat Jul 18, 2020 10:07 pm
Hi !
When I try to open the AutoCAD file, QCAD shows a dot.... Zooming continuously to the dot eventually shows me the drawing, but the pdf export practically doesn't work as the drawing is rendered as a dot in the PDF.
Can you please tell me how I can get the file to render properly?
Thank you so much
Regards
Operating System : Windows 7
QCAD: 3.24.3
K13B Architectural Drawing.dwg
(5.88 MiB) Downloaded 306 times
Re: Pdf rendering not working properly
Post by CVH » Sat Jul 18, 2020 11:11 pm
There is something with the size of block 'TR'
Hiding this block in the Block List won't fool autozoom anymore.
gbhartia
Post by gbhartia » Mon Jul 20, 2020 5:46 pm
Thank you soo much !
