QCAD file compatibility
NPD
Post by NPD » Thu Jul 02, 2020 2:43 pm
How compatible are QCAD file formats AutoCAD and other CAD apps? I saved a file in QCAD 3.24 in R27 DWG format. I sent the file to a vendor and they said they could not open it in AutoCAD? What should I be aware of when creating files in QCAD for use in AutoCAD?
Thanks.
Re: QCAD file compatibility
Post by andrew » Thu Jul 02, 2020 3:51 pm
There are different versions of the DXF/DWG format. You need to check what version of Autocad they have and then export in QCAD for that version.
