Drawing is wrong size
- Junior Member
Using Q Cad version 3.24.3 recently updated. Since updating, a scale error has arisen.When I create a drawing, it is the wrong size. In the attached drawing the large circles were created as 5" diameter, the small circles were 1.44" diameter, and the center to center distance was 6" In some drawings the scale is off by a factor of 4. Rescaling the drawing does not correct issue. In "drawing Preferences," the size scale factor is set to 1.
- Link plate.dxf
- (102.67 KiB) Downloaded 316 times
Re: Drawing is wrong size
Not your drawing is off, your dimensions are created at a scale.
See also:
https://www.qcad.org/rsforum/viewtopic.php?f=33&t=7015
https://www.qcad.org/rsforum/viewtopic.php?f=8&t=5793
See also:
- Junior Member
Thank you! I knew it was something stupid easy!
