QCAD Pro 3.24 Won't Launch Win 10 64b
Jon Sharp
Post by Jon Sharp » Sat May 23, 2020 9:14 am
Hi
I'm a recent upgrade to 3.24 having previously used 3.19 for yrs without problem.
I've had continued issues getting 3.24 to open.
I followed another thread posted previously about removing an opendll file in the plugins folder. This appeared to have worked for a while. Then the other day I noted it had stopped again.
I've tried another removal & install, same issue. It loads to about 50% then nothing.
Tried with AV off too.
Any other suggestions?
TIA
Re: QCAD Pro 3.24 Won't Launch Win 10 64b
Post by Husky » Sat May 23, 2020 9:48 am
You are using the Community Version or the QCAD Professional version? The Pro doesn't requires any file re-movement.
Make also sure that both versions are not mixed in the same subdirectory. Every QCAD installation has to be installed in a new/empty subdirectory.
Post by andrew » Sat May 23, 2020 9:26 pm
I'd do a clean installation from scratch (no need to remove anything).
If it doesn't work, please reset your QCAD installation as described here:
Rantanplan7
Senior Member
Post by Rantanplan7 » Tue Jun 02, 2020 2:17 pm
I had a problem with the installation too - it was an earlier version of QCAD but however.
The fix was to run vcredist_x64.exe - why this was needed / missing on my Windows installation I don't know.
Best Regards
Sven
(former Autosketch 10 user)
