I'm pretty new to QCAD.
When I open a DWG file that has been created with Autocad, the measurements have a too big text size (see attachment).
How could I solve this problem?
Thanks!
P.s. I''m using QCAD Professional 3.22.1.0) On Windows 10 Pro latest update
[solved] Measurements text too big on Autocad files
- capture44.png (31.04 KiB) Viewed 1985 times
Re: Measurements text too big on Autocad files
please check the Dimension settings below Menu / Drawing Preferences and correct the Dimension Text height to something what is better working for you.
Oh, I see.
I thought that it was draw dependent.
Thanks!
Thanks!
