Trim leaves a tail
loxon
Trim leaves a tail
Post by loxon » Mon May 04, 2020 10:52 am
Edit: OS: Win10, QCAD: 3.24.2
I'm having a strange problem where trimming a line leaves a tail beyond the limiting entity. In the attached picture, the blue lines were created using "parallel with distance" from the thick black lines. When I try to trim the ~horiz line to the ~vert it leaves a little overshot tail.
If I draw new lines manually they trim fine. Also, if I split the horizontal entity into multiple segments, it also trims fine.
any advice would be much appreciated
trim tail
trim tail.png (16.87 KiB) Viewed 3908 times
Re: Trim leaves a tail
Post by andrew » Mon May 04, 2020 11:11 am
Please attach your drawing file (DXF, DWG). Reduce to demonstrate problem if necessary.
Post by CVH » Mon May 04, 2020 12:56 pm
Check Z
loxon
Post by loxon » Tue May 05, 2020 8:57 am
Thank you for your replies! I attached a reduced file.
Try to trim one of the horizontal blue lines using a vertical blue line as limiting entity.
I'm new to QCAD so please forgive if I made some silly mistake.
UPDA-R32.dwg
(18.41 KiB) Downloaded 311 times
Post by andrew » Tue May 05, 2020 9:19 am
CVH was spot on: there are several 3D elements with Z coordinates. You can use Misc > Modify > Flatten Drawing to 2D. Obviously this will get rid of the Z coordinates.
loxon
Post by loxon » Tue May 05, 2020 10:02 am
thank you CVH & Andrew. How do I identify the 3D elements? The source of this file is an older format DXF, and I suspect it's created as part if the import.
Post by CVH » Wed May 06, 2020 5:51 pm
Z isnot zero.
