Text edition bug
dfriasb
Senior Member
Text edition bug
Post by dfriasb » Sun Mar 22, 2020 10:51 pm
Hello all,
It seems that some bug is happening when editing text Height property with text editor. QCAD is stopping for some seconds (10-20 aprox.). It's happening to me when both creating or editing a text. In order to reproduce this you can:
  1. Open the attached file
  2. Create new text with T,E
  3. Select Height property content
  4. Delete it. HERE it comes the bug.
I attach dxf file and some screenshots.
DFa.dxf
(108.95 KiB) Downloaded 54 times
3- QCAD thinking about 10-20 seconds.png (216.11 KiB) Viewed 728 times
2- QCAD thinking - monitor.png (240.91 KiB) Viewed 728 times
1- Before selectin text Height.png (222.06 KiB) Viewed 728 times
Re: Text edition bug
Post by andrew » Sun Mar 22, 2020 11:00 pm
Thanks for your report.
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD or indicate the name of the file you have downloaded and installed)
- Attach original drawing files (DXF, DWG, ...) if appropriate
- Attach exported files (SVG, PNG, PDF, ...) if appropriate
- Include screenshots if appropriate
- If there is an error message, indicate the exact message or include a screenshot of the message
- If using a command line tool, indicate that exact command used
Post by CVH » Sun Mar 22, 2020 11:01 pm
I still had to update...
QCADpro 3.23.0.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Can't reproduce.
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Post by Husky » Mon Mar 23, 2020 12:10 am
I can't reproduce that on Win10/64. I've no delay within my editing ...
Note: Your Memory (RAM) is already used to 77%. That is to much and leads to performance issues! Maybe you can test the issue with a lower RAM load.
Shut down your computer (not a restart!),
Boot your computer again.
After it has booted start NO other program except QCAD.
Test the Text editing issue - will it still stop for 20 sec.?
How much RAM in % is used?
enpontus
Post by enpontus » Mon Apr 06, 2020 10:20 am
i see this as well on fedora linux (community edition qcad-3.24.2.6-2.fc31.x86_64) happens at times when changing the numbers (e.g. two backspaces from size 150 =>1 gives me this stop (if i want to change to 125 or so)
