Left select issues
Panchdara
Left select issues
Post by Panchdara » Fri Mar 06, 2020 7:05 am
Good morning. I attach a couple of wmv animations that should highlight my observations. Also attached is the drawing file.
1) Left select a dimension that the selection box touches/intersects a part of that dimension line will select that dimension.
Left select that dimension BUT do not intersect a dimension line.... nothing selected.
2) Artifact??? left select a small part of the drawing and those entities are selected. Then lower center selection point makes sense as it might be to do with the angular dimension. However, selecting a larger area seems to select a bogus point????? I can't find it.
Best
LeftSelection.wmv
Not selecting dimension properly??
(1.46 MiB) Downloaded 388 times
Y-Tube.dxf
(105.91 KiB) Downloaded 381 times
LeftSelection2.wmv
Bogus artifact??
(2.29 MiB) Downloaded 397 times
Windows 10
Re: Left select issues
Post by Husky » Fri Mar 06, 2020 8:12 am
Good morning,
Thanks - reproducible. I tested it with a 35 mm "Extension line Offset". If the selection box is used within the offset it won't select the dim.
Please file a bugreport.
Can't reproduce this. Your example drawing has in that particular area two lines which could represent the " Artifact". If I delete them every thing looks good. How can I try to reproduce that without those lines ...
Panchdara
Post by Panchdara » Fri Mar 06, 2020 8:22 am
Many, many thanks for your investigation.
1) I'll file bug report in a moment... phew, sometimes I wonder whether it's me .... I always doubt myself before thinking of a glitch in the product.
2) I reopened the file and those 2 lines are now visible. I have no idea where they came from.... perhaps playing with intersections. However in my wmv files those 2 lines are not visible....??? Hmmmm? Also, the left select did not "get" those lines unless a larger area was selected. Should I see that anomaly again, I'll save, restart QCAD and reopen...
Thanks again. You have always been of invaluable insight and assistance.
Best
Hugh
Windows 10
Panchdara
Post by Panchdara » Fri Mar 06, 2020 11:46 am
I just received notification that this has been addressed... I got whiplash from this... as the fix occurred so fast... ouch! :lol:
Thank you Andrew.
Best
Windows 10
