Unfortunate bug crash???:
New drawing
Insert bitmap (corrected from video:)
Select bitmap
Rotate bitmap
Select "Reset/Idle"
CRASH
Please see attached. Do you require original bitmap?
Should I create a bugtracker?
Best regards
Insert Image - rotate - reset - crash [SOLVED]
- Video_2020-02-22_142820.wmv
- (4.78 MiB) Downloaded 351 times
Windows 10
Re: Insert Image - rotate - reset - crash
Hi Panchdara - thanks for the heads-up,
https://www.qcad.org/bugtracker/index.p ... sk_id=2046
No. This is a Snapshot bug which was already reported and fixed for the next release.
Thanks Husky. I can't understand that report. Glad it's being sorted.
best regards
best regards
Windows 10
Re: Insert Image - rotate - reset - crash [SOLVED]
Absolutely sorted in new snapshot 3.24.2.6.... Thank you!
Windows 10
