offset round corners
fred-ned2000
Post by fred-ned2000 » Mon Feb 10, 2020 3:02 pm
i want to make a offset (outside) a closed polyline
the original has sharp corners but the offset with a distance has round corners (unwanted)
how if possible can i fix this.
the inside offset is one.
Fred
Re: offset round corners
Post by andrew » Mon Feb 10, 2020 3:15 pm
Have a look at the manual at:
https://qcad.org/doc/qcad/latest/refere ... /OffsetPro
-> Join Types
fred-ned2000
Post by fred-ned2000 » Mon Feb 10, 2020 3:26 pm
Thank you so much.
need to take some time to read the manual.
i made a switch form draftsight to Quad yesterday and start working right away.
Thank you
Fred
