Problem copy/paste a drawing from a file to another [SOLVED]
Philsourish
Post by Philsourish » Fri Jan 24, 2020 12:36 pm
I've a problem when I copy a drawing from one file to another
The copy-pasted drawing shows mismatch : some elements are decalled.
Why ?
Here, the original drawing from existing file
and the copy-pasted drawing
Phil
In annex the .dwg file with the original drawing
Version : 3.24.0.0 (3.24.0) for Linux
Qt Version : 5.13.1
Architecture : x86_64
Compiler : gcc 5.4.0
LEP_DR_BA_-1.BASEMENT_.dwg
(81.1 KiB) Downloaded 380 times
Re: Problem copy/paste a drawing from a file to another.
Post by andrew » Fri Jan 24, 2020 1:18 pm
I cannot reproduce this problem here.
Note that I'm pasting into a new, empty drawing with the same drawing unit. If you are pasting into another drawing with block, you might have a block conflict (same block names with different contents).
Philsourish
Post by Philsourish » Fri Jan 24, 2020 4:57 pm
Thanks for your reply.
You are right.
I wanted to replace the plans of the different floors that an architect sent me (each floor on a separate file) in a single file.
There are indeed, blocks which are different but which have the same names in each file, and this creates conflicts.
Phil
