Windows 10, Qcad pro 3.24.0
Keystrokes do not work in Command Line eg> (@x,y). When I try to draw anything which requires keystrokes nothing happens. Keystrokes do not appear in Command Line.
Qcad is missing 3 buttons in upper right corner. Buttons which Minimize, Resize and Close the screen.
[Solved] Command line does not work and buttons missing
- Missing buttons in upper right corner and Command Line.
- Qcad Errors.jpg (129.38 KiB) Viewed 2491 times
Re: Command line does not work and buttons missing
Is the cursor in the command line field visible? If not click with the mouse in that field or focus to the command line with the keyboard "Space" key.
Your QCAD is in "Full Screen" mode. Use the F11 key on your keyboard to toggle back.
