Linetypes definition [SOLVED]
Philsourish
Post by Philsourish » Mon Jan 13, 2020 9:31 am
I am new with QCAD (3.24.0 Professional for Linux) for 1 week (Before I used DraftSight).
In some old plans, I defined as line types:
"TRACKS": +++++++ (or "Rails" in French)
"BATTING": SSSSSSSSS (or "'isolation" in French)
I see that these linetypes are well defined in the qcadiso.lin file.
With the pattern TRACKS ("+++++") : no problem : it works.
With the pattern BATTTING ("SSSSS") :
in some drawings, it works : the linetype "insulation" is well defined with the pattern "SSSSSSS".
linetype "isolation" with pattern "Batting" : SSSSSS
Capture du 2020-01-13 08-21-22.png (31.59 KiB) Viewed 4667 times
But in other drawings, the linetype "insulation" is empty (no pattern).
linetype "isolation" has no pattern
Capture du 2020-01-13 08-20-28.png (34.43 KiB) Viewed 4667 times
Why this difference ?
It seems to me that those drawings refer to the same .lin file
Thank you for your reply
Re: Linetypes definition
Post by andrew » Mon Jan 13, 2020 9:42 am
Drawing files may contain their own definition of linetypes and override the linetypes defined in the .lin files.
You can reset these drawing internal linetypes using:
Misc > Modify > Reload Linetype Definitions
If you cannot solve the problem, please attach or send the drawing file.
Philsourish
Re: Linetypes definition [Solved]
Post by Philsourish » Mon Jan 13, 2020 11:49 am
Thank you very much for your quick response !
It works !
Is it possible to define new types of lines or must we limit to the predefined types ? (there are already quite a few !)
Post by andrew » Mon Jan 13, 2020 1:34 pm
You can add new linetypes by adding new .lin files under linetypes/metric or linetypes/imperial of your QCAD installation.
Philsourish
Post by Philsourish » Mon Jan 13, 2020 6:28 pm
awesome, it works perfectly!
how to indicate this topic as "SOLVED" ?
Post by CVH » Mon Jan 13, 2020 9:25 pm
Edit you first post.
thanks,
