I am new with QCAD (3.24.0 Professional for Linux) for 1 week (Before I used DraftSight).
In some old plans, I defined as line types:
"TRACKS": +++++++ (or "Rails" in French)
"BATTING": SSSSSSSSS (or "'isolation" in French)
I see that these linetypes are well defined in the qcadiso.lin file.
With the pattern TRACKS ("+++++") : no problem : it works.
With the pattern BATTTING ("SSSSS") :
in some drawings, it works : the linetype "insulation" is well defined with the pattern "SSSSSSS".
But in other drawings, the linetype "insulation" is empty (no pattern).
Why this difference ?
It seems to me that those drawings refer to the same .lin file
Thank you for your reply
Linetypes definition [SOLVED]
- Junior Member
Re: Linetypes definition
Drawing files may contain their own definition of linetypes and override the linetypes defined in the .lin files.
You can reset these drawing internal linetypes using:
Misc > Modify > Reload Linetype Definitions
If you cannot solve the problem, please attach or send the drawing file.
- Junior Member
Re: Linetypes definition [Solved]
Thank you very much for your quick response !
It works !
Is it possible to define new types of lines or must we limit to the predefined types ? (there are already quite a few !)
It works !
You can add new linetypes by adding new .lin files under linetypes/metric or linetypes/imperial of your QCAD installation.
- Junior Member
awesome, it works perfectly!
how to indicate this topic as "SOLVED" ?
Edit you first post.
thanks,
thanks,
