[solved] Stuck in Trial mode
Atbc1
Post by Atbc1 » Sat Jan 04, 2020 10:12 pm
I purchased the windows professional version, received my confirmation email, downloaded through the link in the email and QCAD shuts down like clockwork like im using a trial version. Windows 10 downloaded the 32bit installer on 1/4/2020. How do I fix this issue?
Re: Stuck in Trial mode
Post by Husky » Sat Jan 04, 2020 10:32 pm
Hi Atbc1 - welcome to the QCAD forum.
Sounds like it is still running on trial ...
1. Please deinstall the trial version,
2. please delete also the QCAD3.ini - this link will tell you where to find it on Win10.
https://qcad.org/en/tutorial-resetting- ... on#Windows
3. Install the downloaded full QCAD version. Make sure the used download link suits your system.
https://qcad.org/en/documentation/insta ... er_Windows
4. Keep us posted how it's going.
Atbc1
Post by Atbc1 » Sat Jan 04, 2020 10:52 pm
Thank you very much! So far so good, did not receive any of the this is a trial prompts. Only bummer is lost the drawing I was working on but I guess it will give me more practice.
Post by Husky » Sat Jan 04, 2020 11:56 pm
Great - you're welcome.
Usually that should'n be the case - but .... don't know what happened. :wink:
Make sure to save your drawings outside the QCAD program installation. A location like C:\Users\user\Documents\CAD_drawings or so works best ...
I'll mark this topic as solved. :wink:
