Arc segments off Polylines with widths larger then 180 degrees are rendered faulty.
As is the explosion of such.
The Arc width reduces to zero at the 180 degree marker.
I understand the corner that the math did cut.
Included: example dxf with solution.
Cheers,
Poly with widths & Arc segment > 180 Rendering faulty
- PolyWidthErrLargeArc.dxf
- (113.14 KiB) Downloaded 377 times
