dwg2pdf cli - Hidden Objects
regnete
Post by regnete » Fri Dec 06, 2019 2:37 pm
The createtd PDf contains objects which are hidden in the dwg (and should therfore be hidden in the pdf).
I create the pdf with the following command:
dwg2pdf.bat -n -f -c -block=.*Model_Space.*,.*Paper_Space.* test_hidden_objects.dwg
The expected output is shown in test_hidden_objects_expected.pdf. The actal output is shown in test_hidden_objects_qcad.pdf.
Please watch the differences in the lower right area.
(24.03 KiB) Downloaded 318 times
(4.44 KiB) Downloaded 296 times
(195.6 KiB) Downloaded 309 times
Re: dwg2pdf cli - Hidden Objects
Post by andrew » Fri Dec 06, 2019 2:44 pm
Is this a dynamic block with multiple states? If so, this is not supported in QCAD.
regnete
Post by regnete » Fri Dec 06, 2019 3:04 pm
Yes, they are making heavy use of dynamic blocks.
Are you planing to implement support for this?
Post by andrew » Fri Dec 06, 2019 9:30 pm
Not anytime soon I'm afraid, no.
regnete
Post by regnete » Mon Dec 09, 2019 8:13 am
Could we speed up your efforts with a donation?
Currentyl qcad is the the most reliable solution we found to convert dwg to pdf on the server.
We found only two issues which are relevant to us:
  • lack of support for dynamic blocks
  • Problem when generating multi page pdfs with differing page sizes
We would be willing to support your efforts on providing a solution to these issues with a one time donation?
We don't need support for editing blocks in QCad, we only need support for correct display in exported pdf.
Post by andrew » Mon Dec 09, 2019 2:20 pm
I've had a brief look into dynamic blocks. Hiding those invisible entities of an inactive dynamic block states should be possible with 2-3 hours effort. I will contact you about a possible sponsoring of such a feature.
Can you please elaborate on that? Should the page size vary from page to page? What would the pages show? Thanks.
regnete
Post by regnete » Mon Dec 09, 2019 3:51 pm
Thats sounds great!
I will contact my customer to provide a slim test case for the multi page issue and post it here.
regnete
Post by regnete » Tue Dec 10, 2019 11:06 am
The multi page issue has disappeared as our customer changed the requirements.
So just dynamic blocks feature is pending.
