Cannot load library - qcadnest.dll
FlyingEaglE
Post by FlyingEaglE » Fri Dec 06, 2019 10:12 am
I did not use CAM, the File is there.
What can I do?
C:\Program Files\QCADCAM>"C:\Program Files\QCADCAM\dwg2pdf.bat" -block="(\w*- Layout -\w*)" -auto-fit -center -landscape -paper="A3" -f -outfile="05.pdf" "26.dxf"
02:06:46: Debug: Plugin loader reported error: "Cannot load library C:/Program Files/QCADCAM/plugins/qcadnest.dll: Das angegebene Modul wurde nicht gefunden."
02:06:47: Debug: RGLES3DPlugin::initScriptExtensions
02:06:47: Debug: calling odInitialize
02:06:47: Debug: dropped global XDATA (no res buf): "ViewportCenter"
Converting
to : 05.pdf
02:07:06: Debug: bb: RBox(483895,5.62551e+06: 136.84x126.208)
02:07:07: Debug: f: 0.0021947905082056436
Re: Cannot load library - qcadnest.dll
Post by Husky » Fri Dec 06, 2019 5:44 pm
What can I do?
Question is more likely: What are you trying to do?
Using the dwg2pdf.bat?
On which OS?
With which QCAD Version?
FlyingEaglE
Post by FlyingEaglE » Fri Dec 06, 2019 7:26 pm
Version: 3.23.0.1 (3.23.0)
Win 10
I want to create a multi-page-PDF.
It worked before but now I got this message and it will stand there all the time.
Post by Husky » Sat Dec 07, 2019 1:03 am
Version: 3.23.0.1
Hmm, can't remember a 3.23.0.1. Was that a snapshot? If yes please note:
Quote:
Snapshots are packages with the current development version of QCAD. Snapshots should be considered unstable and are not intended for production use.
Quote end.
I recommend to use the package which was working before.
To address this issue please file a bug report below https://www.qcad.org/bugtracker and state which version was working and which one not. Thank you.
