No longer able todirectly open QCAD-Pro on Mac
eeengineer
Post by eeengineer » Mon Dec 02, 2019 1:43 am
Operating system is Catalina 10.15.1
I get the following error.
"QCAD-Pro.app” can’t be opened because Apple cannot check it for malicious software."
I can open it by bypassing the security protocol but I don not like this solution.
I have version QCAD-Pro Version 3.23.0
Is there a fix planned.
Jim B.
Re: No longer able todirectly open QCAD-Pro on Mac
Post by andrew » Mon Dec 02, 2019 9:40 am
Yes, a fix (Apple's new notarisation) has been implemented. You'll find that if you re-download QCAD 3.23.0 from your personal download link, you will no longer get that warning. You will still get "“QCAD-Pro” is an app downloaded from the internet. Are you sure you want to open it?" which is unavoidable.
eeengineer
Post by eeengineer » Mon Dec 02, 2019 9:58 pm
Thank you, I will try it.
