Horizontal / vertical line tool does not create line
Post by andrew » Thu Nov 28, 2019 5:22 pm
From a QCAD user:
The vertical / horizontal line tools do not create any lines.
Re: Horizontal / vertical line tool does not create line
Post by andrew » Thu Nov 28, 2019 5:23 pm
Please check if the line length in options toolbar is set to the desired length. If the length field is empty or contains a small value, a zero length line or a very short line might be created.
