[solved] Snapshot issue for 3.23.06: Dimension text not showing in Layouts
MPN
Post by MPN » Sat Nov 16, 2019 10:45 am
I'm seeing the following issue in 3.23.06: Dimensions texts are not showing in layouts.
Repro: I opened a dxf file in 3.23.06 (last saved from 3.23.0)
Model (looks like this both in 3.23.0 and 3.23.06):
3.23.0 (showing correctly when double clicking the Layout block)
3.23.06 (not showing dimension ticks and texts when double clicking the Layout block)
Is this a known issue, if not let me know if you need the dxf file to repro.
Note: that when using dwf2pdf I see these errors which might be related:
09:53:27: Debug:    exporting layout: Planer (*Paper_Space2) [3]
Critical: QWinFontEngine: unable to query transformed glyph metrics (GetGlyphOutline() failed, error 1003)... (Cannot complete this function.)
MPN
Re: Snapshot issue for 3.23.06: Dimension text not showing in Layouts
Post by MPN » Sat Nov 16, 2019 11:23 am
After digging around I found that if I set the 'Size scale factor' to 100 the dimensions are rendered again in the Layout but the values are scaled by 100. (Note that my Viewport scale is 0.01 in the Layout block)
.. And then the dimension rendering is 100 times too large in the Model view.
Should I report this in the bug tracker?
Post by Husky » Sat Nov 16, 2019 6:39 pm
Before you do that please attach the dxf/dwg on this posting for further investigation. Thanks.
MPN
Post by MPN » Sat Nov 16, 2019 7:21 pm
Ok, attached here
Udbygning.dxf
(307.05 KiB) Downloaded 575 times
Post by Husky » Sat Nov 16, 2019 8:25 pm
Thanks for the drawing.
Two things ....
1. Yes, I would consider that as a bug too. Please fill the bug report below https://www.qcad.org/bugtracker
I recommend to work with QCAD Pro 3.23.0 until a solution is available
2. On an other note - I'm confused by your used drawing values regarding dim's (has nothing to do with the bug!)
Why is the dim Text height size 15 cm? What should be the printed size? Standard would be 0.35 cm on paper ...
MPN
Post by MPN » Sat Nov 16, 2019 8:49 pm
The 15 cm value worked well when working in the Model space. It has a ok size when using a Viewport with scale 1/100; this gives a height of 0.15 cm when printed (yes it is small, but ok for my use case).
MPN
Post by MPN » Sat Nov 16, 2019 9:01 pm
Thanks. I have reported the bug here: https://www.qcad.org/bugtracker/index.p ... sk_id=1998
Post by Husky » Sat Nov 16, 2019 9:39 pm
Great! Thanks.
Understood - nothing wrong with that!
I always try to keep it simple. With your goals I would use this settings:
But at the end of the day - the result is the same. :wink:
MPN
Post by MPN » Sat Nov 16, 2019 11:06 pm
On the note of scaling dimensions: It would be awesome to have an extra scale factor on viewports that only affected the dimensions of that viewport. Something maybe called: 'Dimensions scale'.
Then I could keep my 0.15 cm dimensions in a viewport with scale 1:50 by setting 'Dimension scale = 0.5'.
And for all my viewports with 1:100 I would leave the default Dimensions scale at 1 (while still keeping my values as in the Dimensions preferences above).
Post by Husky » Sat Nov 16, 2019 11:49 pm
Yes - I would appreciate that too.
I would prefer something closer to the already used terms for Dimension Settings. Maybe called: "Dimension scale factor" or "DIM scale factor"
A Viewport 1:50 would then get the "DIM scale factor" 50
A Viewport 1:100 would then get the "DIM scale factor" 100
A Viewport 10:1 would then get the "DIM scale factor" 0.1
A Viewport 2:1 would then get the "DIM scale factor" 2
and so on - you know what I'm talking about.
Howsoever - here in this forum the idea could get lost. Whats about if you fill a "Feature Request" for that? You can use the bugtracker forum for that:
I'll vote for it. e_surprised
MPN
Post by MPN » Sun Nov 17, 2019 11:13 am
I have submitted a feature request here:
https://www.qcad.org/bugtracker/index.p ... sk_id=1999
MPN
Post by MPN » Sun Nov 17, 2019 7:25 pm
Andrew has already submitted a fix for the issue in this thread so marking it as solved
MPN
Re: [solved] Snapshot issue for 3.23.06: Dimension text not showing in Layouts
Post by MPN » Thu Nov 21, 2019 8:26 am
Verified that the issue is fixed in snapshot 3.23.07
