I'm having trouble with the page tags when I pdf a drawing since downloading the new version of QCAD. I can go to drawing preferences and apply page tags and it will pdf correctly but when I apply page tags in application preferences it doesn't work. So I can manage but it's a pain to have to apply it in every drawing. Thanks for your help.
QCAD 3.23
Windows 7 64 bit
Page Tags Missing
Re: Page Tags Missing
Application Preferences is for new drawings. Drawing Preferences for active drawings.
What is your default start template when you begin a new drawing? The default QCAD drawing or a customized template?
Never mind - I'm able to reproduce it without that info. Regarding to this issue - what was the last working QCAD version?
Howsoever - I recommend to file a bug report below:
That's the best way to address an issue.
