Version QCAD Professional 3.23.0.0 (3.23.0)
Windows 10 Version 10.0.17763 Build 17763
If you draw a line say horizontally from left to right, then draw another line on the top of the original but starting for the original lines endpoint and ending at its start point, now select all, and you will see that there are indeed two lines selected as shown in the property window ‘Line [2]’. If you now perform an MD it says that no duplicate entities have been found.
Note that MD will detect duplicates correctly if lines which are overlaid are in the same direction each time.
Is this a bug?
Terry
Duplicate lines not detected by Detect Duplicates MD
- Detect Duplicates fails to dectect.dxf
- (98.44 KiB) Downloaded 365 times
Re: Duplicate lines not detected by Detect Duplicates MD
Check option "Ignore Direction" in the options toolbar at the top when running the detection.
Thanks Andrew,
I didn't see that option, and yes it works okay.
Terry
Terry
What I call re-tracers are not detected.
Very near a larger original or the 'good path',
very similar angle or supplementary angle,
shorter,
may connect at one ending only.
shorter,
