Edit > Paste does not insert anything
Post by andrew » Tue Sep 03, 2019 2:56 pm
From a QCAD user:
When copying / pasting, nothing is inserted.
Re: Edit > Paste does not insert anything
Post by andrew » Tue Sep 03, 2019 2:59 pm
When pasting:
- Check that the scale factor (options tool bar at the top) is 1 (or the desired scale factor):
Screenshot 2019-09-03 at 15.57.02.png (21.52 KiB) Viewed 2396 times
- Check if the units of the source drawing and the target drawing match. If that is not the case, the pasted objects might be very small or very large.
- Check that the layer(s) you are pasting to are not locked. If in doubt, unlock all layers with Layer > Unlock All Layers.
