Legacy cam scripts behaving abnormally
qharley
Post by qharley » Sat Aug 17, 2019 1:52 pm
I am using a legacy CAM script that is still working fine on the 2.21 version of QCAD-CAM
Something happened in the mean time to break the "Cut inner paths first" function.
Please see the two screenshots attached:
qcad-cam 2.21.2.1
qcad-cam 2.21.2.1 Screenshot from 2019-08-17 14-40-27.png (167.1 KiB) Viewed 5085 times
qcad-cam 2.23
qcad-cam 2.23 Screenshot from 2019-08-17 14-39-14.png (175.19 KiB) Viewed 5085 times
All the settings to create the two files are exactly the same.
qharley
Re: Legacy cam scripts behaving abnormally
Post by qharley » Sat Aug 17, 2019 1:53 pm
Linux 64bit
