Importing SKF files
Rantanplan7
Senior Member
Importing SKF files
Post by Rantanplan7 » Fri Aug 16, 2019 7:24 am
Hi Andrew,
not sure if anyone else has already asked that question, but I have tons of SKF files from Autosketch. I assume there is no way to get them converted to dxf or dwg in an automated way?
So the only way is to open them one by one in Autosketch and save them as dxf?
Anyone else here in the board who might has an idea or maybe already a workaround? I guess there are quite a lot of former Autosketch users around and have the same problem.?
Best Regards
Sven
(former Autosketch 10 user)
Re: Importing SKF files
Post by CVH » Fri Aug 16, 2019 9:22 pm
