Lines disappear when zooming in / out
signal
Post by signal » Mon Apr 29, 2019 2:14 pm
Hi, when i zooming in/out using dwg file some lines disappears and reappears.
look the attachment for details.
Operating System: Windows 10 (64Bit)
QCAD: 3.22.0
Re: Lines disappear when zooming in / out
Post by andrew » Mon Apr 29, 2019 3:04 pm
Please attach your dwg file, so we can try and reproduce the problem here, thanks.
