Block array: Row and column spacing changes when converting drawing units
Posted: Sun Apr 14, 2019 5:41 pm
I inserted a block array into a drawing. When I then convert the drawing units, the row and column spacing is not changed correctly.
Steps to reproduce:
Architecture: x86_64 Windows-10
Steps to reproduce:
- Insert a block with i.e. 3 columns, 2 rows, column spacing 400, row spacing 600 (see before.jpg)
- Edit=>convert drawing unit - from mm to cm
- The distances change by a factor of 10 (see after.jpg).
