combining layers
Nate
combining layers
Post by Nate » Wed Apr 03, 2019 4:06 pm
EXAMPLE I HAVE 4 LAYERS and i want to combine to 1 layer i used to be able to do this with the Move/Copy tool it does not let me do that anymore
Re: combining layers
Post by Husky » Wed Apr 03, 2019 5:20 pm
EXAMPLE I HAVE 4 LAYERS and i want to combine to 1 layer ...
Select all 4 Layer (Layerlist / right mouse click, use the shift key to gather all of them),
Property Editor, change the Layer to the target layer. Done :wink:
Nate
Post by Nate » Wed Apr 03, 2019 6:30 pm
Thanks :D
