Dimension extension line printing problem
LouiseSJPP
Post by LouiseSJPP » Sun Feb 03, 2019 2:42 pm
When I print the extension lines of the dimensions print on top of the actual drawing lines. I'm choosing to print the dimension lines in light grey so the drawing can be seen clearly, but this then leaves gaps in the drawing where the extension lines are.
Is there a way to push the dimension layer down so it doesn't overwrite the drawing lines?
W10, V 3.21.3.0 (3.21.3)
~Errecaldia dining room 02.dxf
(341.16 KiB) Downloaded 44 times
Relic
Re: Dimension extension line printing problem
Post by Relic » Sun Feb 03, 2019 3:44 pm
In the Layer List right-click the layer with the dimensions and choose Select Layer
then use Modify /Draw Order / Send to Back
hope it helps.
Massimo
LouiseSJPP
Post by LouiseSJPP » Thu Feb 07, 2019 3:55 pm
Great, thank you :)
